oliver 88 motor filled
Brad
09-25-2003 15:57:57
I have an 88 motor that has been filled. It seems like it wants to run hot. Any advise would be greatly appreciated
Farmall Daddy
09-26-2003 19:26:08
 Re: oliver 88 motor filled in reply to Brad, 09-25-2003 15:57:57
Make sure your thermostat is in working condition, or just replace it if you haven't. Found out on my M that you have to have one to slow the water down enough to cool it. Good luck!
John
09-26-2003 17:52:52
What classes do you pull, and do you usually kill
the motor?
BRAD
09-26-2003 19:17:58
 Re: Re: oliver 88 motor filled in reply to John, 09-26-2003 17:52:52
John,
New motor, 1st pull tomorrow. I'll let you know
TimC
09-25-2003 18:57:43
I am assuming you have a hole drilled in the back of the head so water flow from back to front.
Run an elec fan so you can continue to cool after you kill the motor. No pun intended.
Same for the water pump.
Add a couple drops of dishwashing liquid to break the surface tension of the water and help cooling.
Run the fuel slightly on the rich side.
I do a little maint on one with block filler, over 300 psi and we don't have any problem but try to avoid back to back pulls. We also use a friction reducing metal treatment. You might ask around or order off the internet. There are a couple products that are probably just like what I use and their brand names are Militec and another is Oil Extreme. Both are extreme pressure additives. I have not used either of these but believe they will do the same thing I use and we don't run any tractor without it.
Brad
09-26-2003 12:01:53
 Re: Re: oliver 88 motor filled in reply to TimC, 09-25-2003 18:57:43
Tim,
Could you please send me your e-mail address or phone #? My e-mail is antqpuller@aol.com. Thanks,
Brad
mta puller
09-25-2003 17:10:07
It has no circulating water, of course it is going to get hot, don't run sideshields.
