NEW TO PULLING
BARRY
09-25-2003 18:14:57
HAVE BEEN MESSING WITH ANTIQUE TRACTORS FOR YEARS.THOUGHT ABOUT TRYING PULLING.WE COLLECT AVERY TRACTORS,AND WOULD LIKE TO TAKE AN R AVERY(SAME AS BF MOLINE)AND MAKE A STOCK PULLER OUT OF IT.IT HAS A GOOD PAIR OF 11.2 TIRES BUT I HAVE ANOTHER R WITH 13.6'S.SHOULD I PUT THE LARGER TIRES ON IT AND DO YOU LOAD THE TIRES(FRONT AND OR BACK) ON A PULLER OR NOT.
2 Cylinder
09-26-2003 07:45:16
 Re: NEW TO PULLING in reply to BARRY, 09-25-2003 18:14:57
If you have the power, I would use the 13.6's because of the bigger tread print on the ground. As for loading the tires, unless they are loaded already I wouldn't go that route. Most pullers will use a suitcase type of weight as you can move it around on the tractor easily to where it is needed for the proper balance, where you cannot do this with loaded tires.
