international 400 questions??
Adam
09-29-2003 07:09:03
I went to a swap meet this weekend and I was told by more than one person that a carb from a 560 will fit on a 400 and make it run stronger for pulling. I asked the guy who had it and he said,"aww yeah it will work good for that". Well the thing isnt even close to fitting. It looks the same but the mounting holes are 90 degrees the other way and it isnt even set up to run the governor rod into the front of it. This thing wasnt all that cheap and I didnt know if there was anyway I could make this work and if I could would I even be gaining that much? I have also heard that the 400 card can be taken and have the ventura hole drilled out and a 806 ventura can be used. Is this true or anothor story and if true how easy is it and how can it be done right? Thanks for any help guys.
Farmall Boy
09-30-2003 12:51:39
 Re: international 400 questions?? in reply to Adam, 09-29-2003 07:09:03
Never heard of a 460 carb on an M...but you can put the bottom half of an 806 on your carb and drill out yor M venturi...heard of a 5 hp gain
Adam
10-01-2003 10:40:40
 Re: Re: international 400 questions?? in reply to Farmall Boy, 09-30-2003 12:51:39
Thanks farmall boy>>
Adam
09-30-2003 06:25:51
Thanks for all the help guys. Hope all of you can help me in the future. I got all of these reply's and didnt know what to think. Must be at least a half page of replys on here.
720Deere
10-01-2003 04:54:17
 Re: Re: international 400 questions?? in reply to Adam, 09-30-2003 06:25:51
Good luck with that attitude there brother!!! When you post sarcastic crap like that, you'll be lucky to get anything. Be patient, sometimes you don't get replies because simply nobody knows the answer. There are also alot of daily posts and yours could quickly be pushed to page 2 where most folks probably don't look. If you don't get an answer in a day or so, repost and maybe reword your posting.
