LARGER SLEEVE
4020PLUS
10-03-2003 12:02:45
want to bore my 4020 diesel to have larger sleeves and pistons. To get 466 cubes I need to use 4.56 dia. pistons and sleeves, can I use pistons and sleeves from a Jd 4240 that has the 4.56 dia. piston or has anyone went whith larger dia. pistons is there enough room in the block to bore bigger? and after reboring block for larger dia. sleeves can you use a permatex sealer to seal the lower part of the sleeves into the block to keep coolant and oil leaking together or do you need to rebore the 0-ring grooves back into the bore, PS after reboring the block there might not be enough room for the o-ring grooves and it probaly is not easy put the grooves back in. is there anyone who has rebored the jd 4020 with larger sleeves and pistons?
