LA case
case puller
10-06-2003 22:39:06
I have an LA case that is built to pull stock. when I started pulling it I could win most of the time (about 5 years ago) but I started getting beat so I build this tractor up more. Got the over bore kit and 3/16th of the head. I have ported and polished the head and manifold. I think it could be a possible winner in division 3 if I would put the right tires on it but I am afraid the rear end wont hold up to the power. I am running a worn out set of 18.4-30 on it now and would like to know what everyone thinks about going to about 18.4-34's. Just a little note...the last time I had it on a dyno it was putting out 110 horsepower.
TROY
10-10-2003 07:36:26
 Re: LA case in reply to case puller, 10-06-2003 22:39:06
A friend has a 505 dodge in front of a LA rear end and has only broke the chains once. And that would not of happened if he wouldn't have shifted down durring the pull.
anotther case puller
10-07-2003 16:35:32
trust me you ain't gonna hurt the rearend. just keep the slack out of the chains and no problem whatsoever. btw i know of a few around that run 200+ and ain't hurt
Mike
10-07-2003 04:32:17
Hey, you are not going to hurt the LA with 110 hp!
Put the tires on, an hold on!!
dctom
10-07-2003 06:55:16
 Re: Re: LA case in reply to Mike, 10-07-2003 04:32:17
YUOU CANT HURT THAT REAR END TURN HER UP AND PUT ON THE BIG TIRES AND GO PULLIN. DCTOM
dan wc ne wyo
10-08-2003 22:00:07
 Re: Re: Re: LA case in reply to dctom, 10-07-2003 06:55:16
L A Case with 4-71 Detroit Diesel engs put out somewhat more power than the gas L A engine. there are several pulling in competion withoutany problems . You could always put in new heavy drive chains to be safe. good luck. dan wc ne wyo.
