making a 1468 run
1468 farmer
10-09-2003 14:43:16
i use a 1468 on the farm and do some pulling was wanting to find some tuning secrets such as timing and head work any ideas?
Pete1468
10-09-2003 15:34:40
 Re: making a 1468 run in reply to 1468 farmer, 10-09-2003 14:43:16
I did a pump once for a 1468 puller. Just install 10mm plungers in the pump and turn up the fuel on a test stand. With twin air research turbo's it will run just the way it is. This one used to pull 10500 class in high 2 and 3 and win consistantly. It's not recomended though, the crankshafts aren't all that strong, but wow did it run, they finally outlawed it because he was winning consistantly.
1468 farmer
10-10-2003 06:09:16
 Re: Re: making a 1468 run in reply to Pete1468, 10-09-2003 15:34:40
thanks for the input pete i forgot to add that it will be pulling in the n/a classes only
