Re: Pistons and Wrist Pins
vjohnyboy
10-22-2003 17:22:35
by moving the wrist pin you can either increase compression or decrease this allowing piston closer to head or farther away second on a stroker if you go from 6 inch to 8 inch this the throw of the crank will increase 1 in each way if you dont shorten the rod or move the wristpin the piston would likely be to close to the head if not hit it this you move the wrist pin or cut rod and shorten it sometimes you do both depending on application i sell pistons that the wrist pin can be bored at a variety of locations about 3 in area
