Chads
10-27-2003 13:50:31
Re: ChadS: H engine build perspective in reply to Buzzman72, 10-24-2003 08:05:42
I can build the 3-5/8 pistons, and a set of rods that will make about 50 to 55 hp with out stroking it.. Using the High dome,, M&Ws out of a 300-350, and then using the offset wrist pin bushing,, I can shoot that compression ratio up 3to5 points just by this method. I would have to cut down the outsides of the pistons in a lathe or mill. and leave the high centers alone,, except to make the piston clear the head. I have done this to a SH a few years back,, worked very well. I won't post the HP,,, because of controversey,, I am offering engines, from stock to bigger power, depends on how much the customer wants to spend for how much HP. I can do the block, and rods and pistons for around 1250.00, with block and rod cores.. Chads
