SUPER(M) CAMSHAFT
BUD BARENIE
11-17-2003 06:33:50
LOOKING FOR INFORMATION ON HOW TO INCREASE TORQUE ON MY SUPER (M) WITH A BETTER CAM GRIND!!
CAN ANYONE EXPLAIN WHAT A DIAL INDICATING THE CAM TELLS A PERSON AND HOW CAN THAT INFO BE UTILIZED !!! LOOKING FOR 20% MORE HP-TORGUE FROM THE SAME BORE AND STROKE !!!! FACTOR OUT HEAD WORK !!!
wildman
11-17-2003 07:16:32
 Re: SUPER(M) CAMSHAFT in reply to BUD BARENIE, 11-17-2003 06:33:50
chads is correct .but tommy richardson would be able to tell you more . 336-854-8254
ChadS
11-17-2003 06:58:43
Dyno tunning will change the way the tractor will run down the track. Sm-450 cam is about the best for a non stroked engine,, About the only change that you could make to the cam is the lobe separation angle,,, But if you don't have ci, and lots of compression,,,, and rpms,, cams will not change it much. Just my 2 cents,,, CHADS
