ChadS
12-01-2003 10:56:30
Hello!! Got some questions for all of ya. Please , no bashing ok? Just want to do something wild HA HA. Here is my plans,, I have a 50 H frame,, and rear end. and a rebuilt 263, 6 cyl engine from a IH 403 combine. I was staring at the both, engine, and the H,, and I think I could put that 6 cyl in that H. Here is where my mind has some questions though.. Some have said that the early 460 tractors were nothing more than H-350 rear ends.. Is this true? Is the 350 and the 460 bellhousing close to being the same? I am not worried about the TA,, in this case, I want to use the H bellhousing. But,, Would the flywheel fit inside the H bell housing? I would not be afraid to build a steel flywheel either. but would still like to use the H starter on it,, I measured the back of the blocks,, both the H, and the 263,, I can build a plate to match up the 6 cyl and the H bellhousing,, and still have room to bolt on the frame rails. How many bolts hold the flywheel to the crank on the 6 cyl? Now,, like I said,, no bashing,, just a country boy who wants a new toy ha ha. Need some help,, any specs that anyone would be nice enough to share,,, I would be very appreciative. Thanks,, ChadS
