pressed steel for WC
anothertractor
12-09-2003 10:02:00
I am trying to get some 12" or 13" x 38" pressed steel wheels for an unstyled AC WC. The bolt pattern is 6 holes with a 7 inch pattern. Does anyone know of a wheel that will bolt up to this? If not, what can I do to the WC to get 9 hole pressed steel wheels to bolt up?
Thanks
Wild Horses
12-09-2003 10:33:49
 Re: pressed steel for WC in reply to anothertractor, 12-09-2003 10:02:00
We've made addapter rings for a 6 to 9 bolt hole. We welded studs in the 9-bolt locations & used bolts/nuts for the 6-bolts. Did this for a DC Case, but should work for a WC. Or you can make a pair of cut-down spokers by welding the 38" ring to a 6-bolt spoke center.
Cody
12-09-2003 17:31:01
 Re: Re: pressed steel for WC in reply to Wild Horses, 12-09-2003 10:33:49
Call Tony Smithson @ 615-794-8979. He makes adapter plates for WC's and WD's to mount 9 bolt wheels. He can make them out of steel or billit aluminum. Very nice work and reasonable too. tell him I sent ya!
anothertractor
12-11-2003 08:55:41
 Re: Re: Re: pressed steel for WC in reply to Cody, 12-09-2003 17:31:01
Thank y,all for your help. Tony is going to send me a set by next week.
