Hitch for AC WC
anothertractor
12-14-2003 06:43:53
My dad and I are building an unstyled AC WC and are getting rady to build the hitch and weight brackets. I am looking for some help mainly on the hitch. We are going to be running 13.6 x 38" tires so the back end is going to be set up a bit. Our club calls for maximum heigh to be 20" to the top of the drawbar and the hole can be no more than 18" from center of axle. Does anyone know where I can find some pictures so I can get some ideas on hitch design. It needs to be adjustable so we can change the height when weight is added. Thanks in advance for any help.
Anothertractor
larry
12-14-2003 17:32:31
 Re: Hitch for AC WC in reply to anothertractor, 12-14-2003 06:43:53
I use the stock hole under rear end. I used angle iron to come off the stock holes under also then extend back and down. I welded a piece of offset angle on outside to use for the adjuster, its at the same angle as the drawbar coming off. I use a bolt on ring that uses a 1 inch bole with a 3/4in drawbar so I can unbolt and raie or lower that much. Gives me plenty of adj. with 14.9/38or 16.9/30
Larry McConnell
12-14-2003 16:45:42
E-mail me and I will send you a photo of my WD hitch Should be about the same as a WC.
