stuck lifters
bud barenie
12-29-2003 15:54:24
i have (2) 264 m blocks, both have stuck lifters,
is it possible to get them out without destroying the block ? need advice, have very little money in these chassis's
all help would be appreaciated
Flogger
12-30-2003 08:23:51
 Re: stuck lifters in reply to bud barenie, 12-29-2003 15:54:24
Hey Bud,
If they are real tight you might need to drive them out the top. Those tappets have holes in the sides and I broke some trying to knock them out the botom.
BUB BARENIE
01-01-2004 08:27:11
 Re: Re: stuck lifters in reply to Flogger, 12-30-2003 08:23:51
WHEN YOU DRIVETHEM OUT, OR WORK THEM OUT WHATEVER!! DOES THAT AFFECT THE THE BORE THEY SLIDE IN. HOW DO YOU FIGURE OUT IF THE LIFTER GALLAY CLEARANCE IS OK ? AND WHAT IS THE BEST WAY TO CLEAN UP THE CONTACT SERFACE THEY RUN IN .
THANKS
Mark
12-29-2003 22:50:41
Bud,lube with penetrating oil,polish the sides that you can get to and tap them out.You may have to work them up and down some before they will come out.Sorry I missed you at Wauseon.
Flogger
01-02-2004 07:42:38
 Re: Re: stuck lifters in reply to Mark, 12-29-2003 22:50:41
Hey Budd,
A brake hone and a little penetrating oil should slick those tappet bores up fine once you get them out.
BUD BARENIE
01-08-2004 15:24:23
 Re: Re: Re: stuck lifters in reply to Flogger, 01-02-2004 07:42:38
GENTLEMEN, THANK YOU FOR YOUR SUPPORT !!!
GREAT ADVISE !!!!
ENJOY THE WINTER, PULLING SEASONIS COMING
BUD BARENIE
