MM ZAU
ChadS
01-04-2004 12:16:30
third party image
MM ZAU in the lean to. Had it running today,, moved it farther in the shed. Sleeping til spring.
BUD BARENIE
01-04-2004 14:32:43
 Re: MM ZAU in reply to ChadS, 01-04-2004 12:16:30
THE PRAIRIE GOLD RUSH !!!!
CHAD OUGHT TO HAVE THAT IN MODIFIED !!!!!
MAN I'M JUST STARTEN TO FALL IN LOVE WITH THAT COLOR !!!!! THINKING ABOUT PUTTING A (G)-MOLINE MOTOR IN A U.B. CHASSIS FOR FARM STOCK !!!! OUCH !!!!!
HAY GOTT PISTONS BUMPIN THE HEAD , WHAT A RELIEF THOUGHT FOR A MOMENT I WAS REDUCED TO CHANGING OOOOOIL !!!!
TALK SOON !!!
BUDD
01-04-2004 12:33:05
Chads;
I know yoyu have been pulling for a long time (a lot longer than me). Here is just a thought, if you would turn your tires around I beleive you would get a lot better grip on the dirt! (LOL)
BUDD ('';'')
Wild Horses
01-05-2004 10:24:04
 Re: Re: MM ZAU in reply to BUDD, 01-04-2004 12:33:05
This was a trick around here in the 70's-80's. They'd pull asphalt one week and dirt the next. By turning the tires around for the asphalt, they would sharpen the bars for the next dirt pull.
I was told a story about my grandpa taking his low rad. Puller G to an asphalt pull. In 9500#, he full pulled and turned the corner at the end of the block. Told the guy he was just going to pull it back around to the start for the next guy. That was one strong G, the more weight the better she did. Hit so hard the front end would bounce when it idled.
Chads
01-04-2004 13:00:06
HA HA HA Would help in dirt. But,, It pulls on blacktop.
