how much hp can i get
4010 nut
01-04-2004 19:12:27
how much horse power can i get out of a johndeere 4010 gas without breaking my wallet or is it better to go with a diesel also how much hp is a stock 4010
Brad
01-05-2004 12:26:43
 Re: how much hp can i get in reply to 4010 nut, 01-04-2004 19:12:27
Definitely go with a gasser if the rpm's are not limited. A gasser will be way cheaper than a diesel (non turbo) Head work would be the most important place not to be cheap on. Can you run a diesel head or oem make and model only? I have to run the stock gas head and struggle to get more than 250-260 CFM Some diesels are near that stock. Next most important thing is probably cam shaft. I dont know what your budget is, but I may be able to help you a little. I have a complete gas engine I am selling to move up to Lim Prostock. Very competitive in western PA non turbo, open rpm, oem manifolds, updraft carb.
Good Luck,
Brad
4010 nut
01-05-2004 16:36:24
 Re: Re: how much hp can i get in reply to Brad, 01-05-2004 12:26:43
well i run pulls around were we live and there are different rules at them all but most are the same some pull shave a ab and c class a is stock and so forth we have alot of dead weight and transfer and i am wanting to pull both i figured the gasser would be better becaues the rpm and i found 2 i is an old tired farm tractor but it has a rebuilt rear end and the other is preatty tired to i thought about eather getting it honed or board a little over and shaving and put big valves in the head change the air system and run a really big carb also put a cam in it ??? also taking off the three point and putting pressed rims on how much will one way andwhat other stuff can i take out every were around here u have to have a pto but i could take hydrolics out i had a 560 i built and took the power steering out and it was a pain to use so i would like to keep the power stearingwhich 4010 should i go for though thanks
buickanddeere
01-04-2004 20:21:37
How far up is "way up there"? How much do you have to spend, how long do you want it to last, what class are you pulling that may limit mods?
