M against a SMTA
cbice
01-09-2004 13:33:28
I pull a stock M in the 6000 lb class . We pull against SMTA,s they always beat the M,s by using the TA.
We tried to get this rule changed but couldn,t. Any opinions? Thanks Clif
Puller504
01-10-2004 09:40:39
 Re: M against a SMTA in reply to cbice, 01-09-2004 13:33:28
My kids pull our IH504 against Farmall M's, 400's and SMTA's in the stock 5000# class. The Row Crop models have 100 or more (sometimes MUCH more) cubic inches than we have. We're competitive ONLY because we know how/when to use the TA on the 504. I farmed with my family with Farmalls for 30 years, models Super C through 806. Dad traded a M for a SuperMTA and never looked back! My advice is to enter the ANTIQUE classes where the TA is not permitted to be used. It's amazing how many M's are pulled in the stock classes that are nowhere near stock! (read the other posts here). I hope this helps, Don
Heads Up
01-11-2004 10:14:55
 Re: Re: M against a SMTA in reply to Puller504, 01-10-2004 09:40:39
When it comes down to it, there really is no such thing as a stock class. Someone is always sneaking in with some secret under the hood.Besides their is really no efficent way to check if a tractor is stock so you just have to fend for yourself, pulling is a game of traction most of the time HP is just a bonus
Dave
01-09-2004 20:31:58
If you can't beat them, find something to cry about, (or try to get the rules changed) and then get them DQ'ed. Sounds like some whinning #%!%#@# who pull against me!!!!!
Clif Bice
01-10-2004 19:45:48
 Re: Re: M against a SMTA in reply to Dave, 01-09-2004 20:31:58
Dave I pull in upstate NY Thanks for your Time
FB
01-09-2004 14:45:06
You can drop an M to 4500 but you'll have to pressed steel on it and it won't look stock but would pull very well.But you should be able to beat him if you get you hitch set up right and use you extra weight to you advantage. The MTA prolly had REALLY sharp tires and if it is a stock class thats where i would put my money at
Wild Horses
01-09-2004 14:35:36
Lose Weight. The Farm stock M's around here stick to 5000-5500#. If your rules allow it, step up to a 4 1/8 overbore kit. Shave the head a little. One stocker here is running that and getting a little over 70 hp.
Matt
01-09-2004 17:24:07
 Re: Re: M against a SMTA in reply to Wild Horses, 01-09-2004 14:35:36
How can they be running an 4 1/8 bore with the head shaved and be getting 70 horse?? There is somthing else in the motor.
earl haman
01-14-2004 13:18:31
 Re: Re: Re: M against a SMTA in reply to Matt, 01-09-2004 17:24:07
I pull a farmall m against super mta's here in central new york. Ican out pull them about 50% of the time in 6500 class and 7500 class.
Donnie
01-09-2004 21:13:30
I would like to see what mine gets on some of these "dnyos". I've got 4 1/4 M and W's, 450 lp head shaved just so the pistons fit the pocket, and a .010 copper head gasket to name just a few. I got a whopping 72hp. I know my dyno is off about 2 or 3 hp. I've checked it against 3 other dynos. I need some of these magic parts.
FB
01-09-2004 18:58:15
might have an M&W crank in it he just doesn't know about
Don
01-09-2004 18:50:02
I got SMTA. Stock block most likely 4 1/8 bore. stock carb. tuned up. different air filter that all. Dynoed at 68hp. I bought it off a farmer who farmed with it for 20 years. So it was not built for pulling til I got it. Take it for what its worth. Don
Farmall Daddy
01-09-2004 17:56:06
I have an M with a bored out motor to a 4 1/8, with a 450 head, milled down block, milled head, stock crank, stock rpm's, fuel system, govenor is all stock. I only have about 64 horsepower.
farmall
01-14-2004 13:14:15
 Re: Re: Re: Re: M against a SMTA in reply to Farmall Daddy, 01-09-2004 17:56:06
yOU NEED TO LOOK AT YOUR CAMSHAFT!
clif bice
01-16-2004 19:35:01
 Re: Re: Re: Re: Re: M against a SMTA in reply to farmall , 01-14-2004 13:14:15
Can you tell me what to get for a cam and where? Thanks Clif
