Cut tires
Allen
01-10-2004 18:39:17
What would be the best tire ? 18.4 X 38 151 Firestone cut or 18.4 X 38 radial long bar - long bar cut.
Mike Aylward
01-11-2004 06:17:36
 Re: Cut tires in reply to Allen, 01-10-2004 18:39:17
Allen, it depends on what weight and class of tractor you are using these tires on. Let us know and we will try to give you our best "guess". Mike
Allen
01-11-2004 08:05:40
 Re: Re: Cut tires in reply to Mike Aylward, 01-11-2004 06:17:36
Thanks for the reply. tractor will be running the coatpa div.5 class. 7500 lb. turbo.
Mike Aylward
01-11-2004 15:49:45
 Re: Re: Re: Cut tires in reply to Allen, 01-11-2004 08:05:40
Allen, to be honest it would about be a draw, but I would probably recommend the bias tire. The radials don't really start coming into their own until you get to a heavier class. You will likely do ok with either tire, but I believe you would be happier with the bias tire at that weight class. Others may differ, but this is what I have seen in the midwest. Mike
