Moline GVI ?
CPoosch
01-20-2004 07:25:35
How difficult/expensive would it be to convert a GVI from LPG to gas?
CP
mike's 600
01-21-2004 19:07:48
 Re: Moline GVI ? in reply to CPoosch, 01-20-2004 07:25:35
why convert to gas?
Chris Sublett
01-20-2004 18:25:15
A friend of mine has a carb that came off a 605 gas. I think its a Zenith. It would need to be rebuilt but I think he would sell it if you are interested. Thanks Chris
Turbinr Dude
01-20-2004 16:54:23
You can do this very easily as mentioned but you need to go to a bigger carb, if you can find a carb from a gasoline G-1000 that would be more favorable. The carb from the 670 isn't big enough to optimize the power or size of the engine. If you have access to some parts books if so they did build the GVI's in Gasoline from the factory i think about a 100 give or take see what the parts books have for a carb p/n if being close to stock is desired
E J
01-20-2004 09:28:16
I am changing one over too .Went to salvage yard and bought a diesel hood and fuel tank and already had a big carb made linkage from origonal govenor to carb plus fuel line from tank.I think a carb off of a 670mm tsx-693 will work on your manifold.Didn't spend much to do it under 150.00
Cody
01-21-2004 05:56:38
 Re: Re: Moline GVI ? in reply to E J, 01-20-2004 09:28:16
I've got a big carb with the same size troat as the original LP carbs. Good Shape. $300
