ChadS
01-22-2004 20:35:13
Re: Re: Re: Re: Flywheel Questions in reply to Heavy Iron, 01-22-2004 18:39:17
It has no torque curve, it that what you are saying? any engine should increase HP when you lug it down,, even if it is only 2-5 hp before it drops off. If you have not got the carb set up foe the engine to lug down that far to low rpm,, it will die faster than usual. Just re jet it, you should be able to make it run rich when you back out the load adjustment. For an engine to increase torque,, it needs the proper fuel. And if it has more fuel, it will have more lug, and can handle the heavier parts and create more torque. It is called centrifical balance, more weight to spin, the longer it takes to slow down to stop, it creates energy, or inertia, or what ever the scientific term for it is. Just my opinion, I have tried it with Farmalls too, same result. I have actually made a ring that fits the outside of the flywheel behind the starter ring to make it heavier,, had it re balanced, and got 10 more hp on the torque curve, (below 540) and that is on a stock engine. Chad
