Oliver 88 question
ChadS
01-28-2004 17:17:03
The ol 88 has a problem,, it had calcium in the tires, and leaked onto the axle shaft and rotted it out something badly, I have a few 77's laying around and was wondering if the 77 axles and housings will work on the 88? I have both super and non super axles for the 77 if that helps,,, Any info would be great,, Thanks in adavance!! Chad
dan
01-28-2004 17:53:51
 Re: Oliver 88 question in reply to ChadS, 01-28-2004 17:17:03
check the axle diameters. if they are the same they should work. i know the super 88 is bigger than the 88. the spline in the final is the same size as the outside. not sure if 77 final will swap with 88.
Mr. Oversight
01-28-2004 18:10:35
 Re: Re: Oliver 88 question in reply to dan , 01-28-2004 17:53:51
They will not swap out. The 88 has a different bolt pattern on the axle housing than the 77.
ChadS
01-28-2004 18:36:25
 Re: Re: Re: Oliver 88 question in reply to Mr. Oversight, 01-28-2004 18:10:35
Thanks Guys!! Chad
