John Deere G head question
520-LP
01-28-2004 18:56:09
I am putting a G together with 125 over M&W style pistons.cam with 580 lift,and put a flat head on it and had a 195 pounds compression.The flat head is busted in around the intake guide beyond repair now the ??? How much compression and HP will I loose by useing a regular head Thanks
TimC
01-29-2004 06:08:33
 Re: John Deere G head question in reply to 520-LP, 01-28-2004 18:56:09
Most any head is repairable. I've seen heads repaired that had a valve come loose and beat out the quench area into the water jacket and trashed the bowl.
advice
01-29-2004 21:10:32
 Re: Re: John Deere G head question in reply to TimC, 01-29-2004 06:08:33
listen to actual pullers some as Scott Boehler, not people who just talk, like TIMC. Go watch the Under Pressure 88 that TIMC works on, you'll see what I mean!! It runs OK if it was a 320 inch 88! What a sad sight! Maybe he quenched it too much!!
TimC
01-30-2004 09:31:16
 Re: Re: Re: John Deere G head question in reply to advice, 01-29-2004 21:10:32
Hope you are enjoying the nice warm weather down there in Texas and your brand of humor at my expense. Next time at least make it funny. I enjoy a good laugh now and then too.
in reality
01-28-2004 20:02:27
if you take a style head and shave it down as far as you can you will lose a little compression compared to a flat head, but probably not any horsepower. my experience is a shaved style head and flathead are as good as the other, and some people say the style head will give you more torque.
JDGnut
01-28-2004 19:31:01
Not sure on the HP..... You will losed a lot.. with just the M&W style pistons will have about 6.5 to 1 ratio... If U havn't cut any thing off the block.. It will take some work to make up the compression.. and If you are going to go back to a flathead.. You could cut down a styled head for a while... but it will get U by.. A million different things U can do to get the compression back using the styled head.. but will take some work.. JDGnut
Scott Boehler
01-28-2004 19:24:14
520, Are you sure the is not repairable. I don't
know where you are located but there is a place in Mt Vernon Il that is real good at repairing heads. They welded one up for me. I will see if I can find the name and number so please email me. Scott
