A John Deere
A from Ky
01-30-2004 17:50:13
I have just got an A John Deere and have the power block and hiesler head for it.Anybody have an idea what kind of HP could get out of it.I would rather not stroke it,any other ideas on gaining power.This tractor has the fast transmision,and I want to pull it in a 3mph class 4500 5000.Think this will work.Thanks
jd puller
01-31-2004 20:37:38
 Re: A John Deere in reply to A from Ky, 01-30-2004 17:50:13
all I can say is that my 37 A has the later crank so its only stroked 1/8 inch has .90 over cast iron pistons, stock head with a lot of messaging, a all fuel manifold a dltx 71 carb and orriginal air breather, I have a set of custom donuts and I am cranking 65 hp know I can put a set of 2.5-1 rocker arms and JD 70 gas pistons in it and get 75-80
and by the way dont bring it went of the mississippi....it wount compete unless its sroked and bored to about 700 cubic inches
tommy
02-01-2004 17:02:48
 Re: Re: A John Deere in reply to jd puller, 01-31-2004 20:37:38
You are so full of crap!
a puller
01-31-2004 21:20:33
how does it do that when A's with 9" stroke and 6.125" bore only get 75-80 hp???
Green weenie
01-30-2004 19:10:56
It might work pretty good in your country but don*t bring it North or west of St. Louis and expect to clean house, we got B John Deeres in this country bigger than that, maybe strong in Div.2 though..
a puller
01-30-2004 18:10:34
a solid 50 is what I would guess...
