IH 429 injectors
1256 Puller
02-01-2004 12:33:51
Does anyone know where I could find injectors from a 429 either used ,new or rebuit? Also any performance info would be appreciated on the roosamaster pumps.
E J
02-02-2004 03:34:56
 Re: IH 429 injectors in reply to 1256 Puller, 02-01-2004 12:33:51
If you go to the IH forum about page 13 you will see a 1206 blowing smoke in the air thats mine that has a turned up 390 with 429 injectors.
E J
02-01-2004 15:12:09
Got my tips through case ih came out of califronia 39 per tip abought same price as stock ones.If you put a 450 on will have to get bigger lines or you will twist the pump shaft off.May have to take the transfer pump off and run a boost pump instead a 450 puts out allot of cc of fuel.Check with your local pump shop on line size & injectors
1206SWMO
02-01-2004 18:14:31
 Re: Re: IH 429 injectors in reply to E J, 02-01-2004 15:12:09
EJ is right.You will need .093 lines to run a .450 pump head.Back in the late 60's-early 70's I saw many a DT361-DT407 IH twist off a pump shaft even when running with big lines.
