oil pump
beginer puller
02-02-2004 15:31:06
does anyone know where I can get an affordable belt driven oil pump or have a suggestion of what type to use???? any help on this will be great THANKS!!!
TimC
02-09-2004 19:04:43
 Re: oil pump in reply to beginer puller, 02-02-2004 15:31:06
Sorry for the delay. Was busy this weekend getting another project finished. Shoot me an email at tim.crutcher@netzero.net-----or com.
Not sure which. If i don'thear back when i get it i'll just re post the info.
The emails would be better. It won't let me forget.
puller
02-04-2004 16:20:47
I don't won't to start a war. I just need some help!!! I enjoy all the input, but seriously I need some good advice! thanks everyone!!!!! !!
Allis
02-04-2004 13:59:24
a hyd pump will work, but you will need to figure out the displacement and speed that the original one turns and pumps than find a comparable size hyd pump and drive it close to the same speed. use a pressure regulater and a remote mount filter base to controll oil pressure. Dry sump pumps for raceing applications work well driven off front pully. Don't use too big of pump or you are just pumping extra oil and wasteing power. I have one that fits where a magneto would, let me know and I can find one or tell you where to get one
TimC
02-02-2004 19:25:10
Hydrolic pump w/pulley driven by front pulley. Will have to figure out pulley sizes to run proper volume and use an aftermarket pressure regulator. Then you have to figure out the filter and plumbing. This also helps take the load off of cams that have been ground down in stroker motors. I removed the exterior (heavy) oil filter assembly and installed a remote filter behind the radiator fan with hydrolic hoses. I made my own pressure regulator out of a billet peice of aluminum some fittings and a spring and ball bearing.
This allows 25 lbs hot at idle and 45 lbs at 3 grand with factory pump. Hydrolic pump should do the same.
PULLER
02-02-2004 20:31:14
 Re: Re: oil pump in reply to TimC, 02-02-2004 19:25:10
what can I find one of those hydrolic pumps on or what do I ask for to buy a new one? do you have a pully size? thanks you have already been some help.
buickanddeere .......hydr
02-04-2004 07:48:13
 Re: Re: Re: oil pump in reply to PULLER, 02-02-2004 20:31:14
The Summit racing catalogue has pages of external oil pumps etc for wet and dry sump engine lube systems. Always wondered why dry sumps are uncommon with even highly modified engines.
TimC
02-03-2004 06:34:44
I can get a p/n this weekend and a pulley size.
puller
02-03-2004 21:40:31
 Re: Re: Re: Re: oil pump in reply to TimC, 02-03-2004 06:34:44
thanks alot I'll be looking for your post
LIAR!!!
02-04-2004 10:10:10
 Re: Re: Re: Re: Re: oil pump in reply to puller, 02-03-2004 21:40:31
You need to call Duke Harrington!! He is the guy who put came up with the hydraulic pump idea and made it work!! Ole Timmy just claimed he was the engineer and figured it all out. You need to but a 1-2-or 3 stage pump that is made just for this. You can find a used one froma sprint car, etc.. Belive me you don't want to use a hydraulic pump if it will make your tractor run like Randy Head's oliver(Tilley's old tractor)(TimC chief engineer and B.S.er)!
TimC
02-04-2004 14:26:04
 Re: Re: Re: Re: Re: Re: oil pump in reply to LIAR!!!, 02-04-2004 10:10:10
So you don't misunderstand let me explain it in ways you will understand.
Re-read to see I took no credit on using that type oil pump. Just told him what could work.
The home made pressure regulator whet on a Red Diamond motor where I removed the external oil assembly which houses the over pressure bypass on Don's 600 cid 460. Is there any other little detail I need to clarify for you?
barr
09-29-2005 05:55:43
 Re: Re: Re: Re: Re: Re: Re: oil pump in reply to TimC, 02-04-2004 14:26:04
i'm looking for a red diamond motor for a 460 farmall
