ChadS
02-09-2004 10:55:40
Re: Re: Wild Horses in reply to Wild Horses, 02-09-2004 10:12:50
I built a steering shaft for it, I had made a frame that bolts on to the tractor, and it is for the sheet metal, I made it all one piece, the whole hood can tilt, or be removed by 6 bolts. Dad is going to put one together too, he is wanting the big engine, and going to use H sheetmetal. Really, the one I built, I made in to the 460, If I ever build a big cube engine, (301 block) I want to run div 4 and 5 and get light. It does look better,, LOL square front, instead of a peak,, I don't think it will be much under 3500, real close,, I still have cast hubs, (ol 77) and a stock H seat. Still could lose another 200-250 lbs pretty easy, but I think I will just run it see how it will balance out. The engine seems to be pretty strong,, after changing fuel, and building a carb, and a few other things, My estimate it would run 3rd gear solidly with 18.4x34. up to 4500, not very fast on ground speed but should be enough to have some fun. Chad
