Tachometers
39H PULLER
02-12-2004 19:53:00
Wanting to put a tach on my H, wondering what you guys are using?
Proredpuller
02-13-2004 09:53:24
 Re: Tachometers in reply to 39H PULLER, 02-12-2004 19:53:00
I use a digital tach but will have to look through my records to let you know where I purchased my last one. The type of tach I use are intended for marine applications where you are synchronizing two engines. You can research them on the web, just search on digital tach and you'll find them. They usually run around $260 but are quite good and bright. I've used them with point systems or with MSD boxes and they are pretty resilient and accurate to within 1 RPM. But, if you go this way, watch out for cheap versions becuase they will be suseptible to noise and will bounce all over and be useless. Just my 2 cents worth. Good luck.
