rods
a puller
02-16-2004 18:59:51
does anyone know what rods are out there for the best clearence on a 2.5" journal? thanks alot
TimC
02-16-2004 20:58:06
 Re: rods in reply to a puller, 02-16-2004 18:59:51
You might find a
ford 370 385 429 460 with 2.5 inch journal
Olds 371 394 2.5 in journal from 1949 to 1964
Olds 400 425 455 64 to present
Caddy 472 500 1967 to 76
but you didn't specify rod length. Kind of a loaded question.
Don't have tractor rod info handy.
If you off center grind to 2.250 or 2.0 your choices increase greatly.
a puller
02-17-2004 11:35:30
 Re: Re: rods in reply to TimC, 02-16-2004 20:58:06
I just was looking for a rod that is heavy to put in a U moline with 2.5" journals.....thanks alot
TimC
02-17-2004 12:50:54
 Re: Re: Re: rods in reply to a puller, 02-17-2004 11:35:30
But now you've stoked it so you need a shorter rod?
joe
02-17-2004 15:07:38
 Re: Re: Re: Re: rods in reply to TimC, 02-17-2004 12:50:54
I used M rods at the full 10" length with 7.5" stroke in my U.
a puller
02-17-2004 16:10:55
 Re: Re: Re: Re: Re: rods in reply to joe, 02-17-2004 15:07:38
is that a 2.5" journal? or how big is a M rod? thanks
joe
02-17-2004 17:01:25
 Re: Re: Re: Re: Re: Re: rods in reply to a puller, 02-17-2004 16:10:55
Sorry but I don't remember but I'm sure someone on here could give u the spec. So your crank is already done ? Did u buy the one on MM.com?
a puller
02-17-2004 17:14:09
 Re: Re: Re: Re: Re: Re: Re: rods in reply to joe , 02-17-2004 17:01:25
yes, that is the crank I'm talking about. thanks alot though...
