Piston Decking
Agdude
02-16-2004 22:26:55
I am looking at some pistons for my pulling tractor that will work good if I mill about .075" off the top. Will most aluminum auto pistons stand this? They are flat with valve reliefs. I'm a little worried.
Proredpuller
02-17-2004 05:55:13
 Re: Piston Decking in reply to Agdude, 02-16-2004 22:26:55
As a rule of thumb, you can go as thin as .175 (depending upon the quality of the material used)and be safe as long as its a naturally aspirated engine and no NOS. Just measure the thickness and see what you've got. Sometimes this can be a little challenging with valve reliefs but you can get close. I usually try to stay in the .200 range with forged pistons but have seen folks go as low as .165 and work just fine. Hope that helps.
Agdude
02-17-2004 19:12:37
 Re: Re: Piston Decking in reply to Proredpuller, 02-17-2004 05:55:13
It sure does help. Thank you.
CASEPOWER
02-17-2004 05:36:27
.075 is not much for most pistons. I just took .130 off of a chevy BB 366 piston. It had one relief and was a clevite. Most of the cast pistons are very thick.
Agdude
02-17-2004 19:10:59
 Re: Re: Piston Decking in reply to CASEPOWER, 02-17-2004 05:36:27
Was that a forged piston?
TimC
02-17-2004 19:19:15
 Re: Re: Re: Piston Decking in reply to Agdude, 02-17-2004 19:10:59
Cast pistons are poured into a mold and forged pistons are stamped (for lack of a better word) under heat and pressure as I understand it. It makes a denser stonger lighter piston.
When milling it is also a good time to design the floor of the combustion chamber which is the top of the piston if you know what I'm getting at.
