9 bolt hubs
Asa Buck
02-17-2004 16:47:15
Will 88-1650 M&W hubs fit on a farmall M. If so
do they fit perfect or do they need mod.?
Larry
02-17-2004 21:09:09
 Re: 9 bolt hubs in reply to Asa Buck, 02-17-2004 16:47:15
You'll have a lot less headaches if you find hubs from an IH, or you can get hubs from a D-19 or early 190 Allis, they are the same size axle and key as well.
dan
02-17-2004 19:56:22
if the axle diameter is the same. oliver has different sizes. the other difference is the width of the key.
SPT
02-17-2004 17:37:38
Green tractor, the other green painted black, and now a red tractor???? More the better, bring 'em all.
See you at Princeton.
Smith Pulling Team
