IGNITION msd
a puller
02-24-2004 16:25:58
I recently bought a 6al msd box from jegs with the blaster 2 coil. was wondering if there is a dyno seen performance result? thanks alot.
ChadS
02-24-2004 18:47:25
 Re: IGNITION msd in reply to a puller, 02-24-2004 16:25:58
If you have good plugs, and wires, and point, or electronic igntion, with the MSD, you are ablw to burn more fuel in the engine and no foul out the plugs so fast. You won't really see a HP increase by the igntion itself, it is the change you make to compliment the ignition. Should be able to run more fuel, and possibly more cfm on the carb. Just my 2 cents. pic of the 460-H in tractor photos. ChadS
