Using Wet Clutch for pulling
allispuller
02-29-2004 20:47:43
I am building a Div 3 tractor, looking for Ideas as to if it a good thing to run the wet clutch and if it will stand the abuse of the higher horsepower motor? if so what should I do to it, to help work and not burn out?
L Hud
03-01-2004 07:50:24
 Re: Using Wet Clutch for pulling in reply to allispuller, 02-29-2004 20:47:43
You can take all the shims out and lock it up. It will hold a lot that way. If it does slip, you can build a coupler to replace the clutch. Hope this helps.
