cold air intake
Andrew
03-04-2004 10:26:46
if i run a pipe right of the intake on the carb and put a cone air filter on it do i have to adjust anything on the carb such as the air fuel mix thanks
TimC
03-04-2004 17:55:42
 Re: cold air intake in reply to Andrew, 03-04-2004 10:26:46
If you get more cool dense air in it then you are obviously going to get more oxy molecules in there too. So you can add more fuel and get it to burn.
Farmall Super M Puller
03-04-2004 16:41:36
Put a K&N cone air filter on it. You might have to do a lil adjusting on the carb but this set up should give you some more H.P. along with the added plus of a fliter system. By the way what are you going to run this on.
