Want to build a puller out of a MM GBD
Alberta Green H
11-15-2001 08:24:25
If any of you guys could give a "wet behind the ears" guy some info on what to do to a MMGBD to make a good puller out of it, it would be appreciated. I'm Restoring it now and have heard that putting 504 blocks and using the original heads (from 425-6 D) is easy and cheap. What do you think, any other suggestions. Thanks in advance..... ..
MM man
11-16-2001 04:48:32
 Re: Want to build a puller out of a MM GBD in reply to Alberta Green Horn, 11-15-2001 08:24:25
The other replys are ok. But you can get alot more! Bore and stroke, 200hp is easy.
John Mann
11-15-2001 09:52:06
I had one of those with the 504 in it. I was great up to about 11000 lbs , then gearing was to high. The heads you have will work , I think you would be better off with a newer style head, they should be higher compression , spend some time opening up the ports with the valves removed. Change the pump drive to the roosa master style and find a roosa and lineset. Get a g 1000 intake and exhaust . Have the pump calibrated to G 1000 specifications and adjust fuel about 15% more. This combo is good for about 120 hp, also change the cam to a 1000 cam. I have a 990 oliver still that I pull and it never would handle the old mo. One problem I had at first the fuel was set to high and it was smothering out. Good Luck
A.G.H
11-15-2001 10:49:18
 Re: Re: Want to build a puller out of a MM GBD in reply to John Mann, 11-15-2001 09:52:06
Thanks John, looks like I have some parts hunting to do! Any ideas? appreciate all your help....MT
