Re: Re: Re: straight pipe mufflers
paul
03-15-2004 18:36:42
Expanded metal is just like raised diamond plate sheeting with the diamonds cut out and is used for traction on walk ways and loading ramps.It comes in different thickness,go to a metal fab shop and they should have some scraps. get the thinest so you can push it into the pipe and it will stay there if you cut the same or slightly bigger than the ID of your pipe.Hope I didnt really confuse you.
Angus
03-15-2004 19:46:01
 Re: Re: Re: Re: straight pipe mufflers in reply to paul, 03-15-2004 18:36:42
So i bend the expanded metal into a tube form similar to the chrome pipe? and then stuff coarse steel wool between the inside of the pipe and the outside of the expanded tube structure?
a puller
03-15-2004 19:55:50
 Re: Re: Re: Re: Re: straight pipe mufflers in reply to Angus, 03-15-2004 19:46:01
I believe he means make it like a sandwhich, the steel wool being the meat, and the 2 chuncks of steel being the bread. make it just a few thousandths bigger then the pipe..or you can just spot weld the steel in there..and then put another piece on top. ___IoI_____the __are one side of the pipe, and the "I" is the diamond cut out metal....and the o is the steel wool...hope this helps(sorry, I couldnt' make the other wall of the pipe..lol)
hope this helps some...
Angus
03-15-2004 20:05:42
 Re: Re: Re: Re: Re: Re: straight pipe mufflers in reply to a puller, 03-15-2004 19:55:50
Ok so there is no open hole through the actual pipe. The exhaust must pass through the steel wool as if it was a "steel wool cork" blocking the pipe, if this is what you mean then it sounds like a great idea!
a puller
03-15-2004 20:47:09
 Re: Re: Re: Re: Re: Re: Re: straight pipe mufflers in reply to Angus, 03-15-2004 20:05:42
this is what i gathered from it..kinda a baffeler..hense the muffle sound..:S...I personally don't know why they would have a no straight pipe rule?? alot of the fun is the noise!!
