looking for JD-B light prest steel in MI
45 M
03-17-2004 11:44:09
I am looking for 3-4 sets of John Deere B prest steel wheels with the light centers the wider the better. The B's have the lighter rims and centers than an A. I live in Michigan so please not to far away.
Larry806
03-17-2004 20:42:05
 Re: looking for JD-B light prest steel in MI in reply to 45 M, 03-17-2004 11:44:09
I have several set's of pressed steel rims some came off of B's I have a set that has been widened to 15 in bead I think Has a set of 15.5-38 tires on them
2 Cylinder
03-17-2004 16:34:14
The only thing I can tell you if it has to be from a JD-B, is from an antique tractor salvage yard, but you'll probably pay dearly. Where in Michigan are you located?
45 M
03-18-2004 06:53:43
 Re: Re: looking for JD-B light prest steel in MI in reply to 2 Cylinder, 03-17-2004 16:34:14
I live in Mt.Pleasant MI I think that it is true that the B's are a little lighter than the A's but maby not.
Keddano
03-19-2004 20:17:14
 Re: Re: Re: looking for JD-B light prest steel in in reply to 45 M, 03-18-2004 06:53:43
Steel Press should be about the same,Finding ones that are factory from a "B" vs. a "A" is next to impossible. Go with what size you need and lose weight somewhere else.
