tire cuttin no-good cheaters
bud barenie
03-19-2004 16:48:13
pulling division (1) or farm stock as called in our club !!
just seen several sets of tires (cut) on the baxk side.
lookes like they used a belt sander !! the line, or darker rubber markes are evident !!!
question !!! if the rules say non-cut tires, what does that mean !!!
does non cut mean do not cut or go ahead and grind !!
how can you identify if a tire has benn modified !!
hi---llllyy pizzzzed!! in indiana
Wild Horses
03-22-2004 10:26:08
 Re: tire cuttin no-good cheaters in reply to bud barenie, 03-19-2004 16:48:13
Are you sure they didn't sharpen them on pavement?
ron
03-22-2004 12:01:33
 Re: Re: tire cuttin no-good cheaters in reply to Wild Horses, 03-22-2004 10:26:08
See what I mean. What is the difference in sharpening on pavement or using a belt sander?
Ollie Puller 2
03-20-2004 07:19:48
Ask John Lambkin of USAP. He started all of this Farm Stock "tire cutting" because he could not enforce his rules????
ron
03-20-2004 14:01:51
 Re: Re: tire cuttin no-good cheaters in reply to Ollie Puller 2, 03-20-2004 07:19:48
Personaly I think you should be able to grind or plane the back of tires as long as you do no touch lead edge. You ask why? Because I can buy tire off of a farm tractor that has been road wore and go pull that has a great edge. Or I can use a set leaning against my corn crib for less money. The no cut rule cause you to spend money other-wise you would not have to spend. That is why we did that oruond here. Do not touch lead edge.
