dist advance
andy
03-22-2004 16:31:08
Does anyone have any advice on the advance curves of a dist for pulling? 2500rpm max
TimC
03-22-2004 19:28:41
 Re: dist advance in reply to andy, 03-22-2004 16:31:08
You could hook a timing light to it and check to see what you have first. Then go to a light spring for more advance or heavier spring for less advance (I believe thats how it works). Then if you are adding more rpms you might go with a heavier spring and to hold off the advance until you reach the higher rpms. Just something to think about. A dyno would tell you where the best advance should fall if you happen to have a buddy that had a dyno.
