High domed piston photo
ChadS
03-25-2004 06:07:56
third party image
I remachined this piston to accept a 1 in stroker, and it is a IH piston. this is a small domed piston, I have a piston made, that makes this dome look tiny!!! LOL!! Think it will build some compression???? Chad
buickanddeere
03-25-2004 22:04:30
 Re: High domed piston photo in reply to ChadS, 03-25-2004 06:07:56
Just using a couple of rings or machined more grooves down the piston?
ChadS
03-26-2004 08:06:37
 Re: Re: High domed piston photo in reply to buickanddeere, 03-25-2004 22:04:30
All the rings are still there, in stock location. Chad
CASEPOWER
03-25-2004 12:44:13
After the stroker crank and the dome what is your compression gonna be? Looks like a high rpm turning, no torque set-up at low RPM's. Would love to hear your prefered comression. I picked up a RD 372 engine today. Anyone need one??
Flogger
03-25-2004 07:51:12
Are those for use with a kerosene cyl head? Pulled a set out of my M a few years ago that looked about like that.
ChadS
03-25-2004 08:51:28
 Re: Re: High domed piston photo in reply to Flogger , 03-25-2004 07:51:12
That piston is an old stock flat top, I machined it to make a dome on it, Yeah that top design is a IH design, came from the old stepped head piston. Yes, it would fit 8060 heads, and like chambers. I have a few different cuts for different heads, like the LP, 450, and regular M heads. I was just messing arond with the flat top you see, The other design is has about 13/16 dome on it. it is designed for a stroker, and keeps the cost down finding pistons for smaller stroker engines. Chad
Double T
03-25-2004 06:14:06
That block looks to short atleast two holes anyway
ChadS
03-25-2004 06:24:34
 Re: Re: High domed piston photo in reply to Double T, 03-25-2004 06:14:06
That is a M block, 4 cyl. LOL but can do the same thing to a 6 cyl. Chad
Buzzman72
03-25-2004 07:16:27
 Re: Re: Re: High domed piston photo in reply to ChadS, 03-25-2004 06:24:34
Chad, as my ol' daddy used to say, I was born stupid and lost ground ever since...but I don't figure that sort of dome would work on a Farmall 6 with a truck head...would it? At least not without a spacer!
ChadS
03-25-2004 08:43:08
 Re: Re: Re: Re: High domed piston photo in reply to Buzzman72, 03-25-2004 07:16:27
No, not with a truck head, the tractor head can handle a bit bigger dome in the chamber. the truck heads, as you know, take a flat top piston, yeah you could put a very small dome in it, but would have to cut valve reliefs in the piston. Chad
