Looking for IH 6 cyl stroker crank
AC
03-30-2004 16:46:48
Anyone have a used stroked crank for a C301 block? Also, what are some of the engine combinations that you all are running, esp bore sizes...thanks, AC
Puller
03-30-2004 18:16:21
 Re: Looking for IH 6 cyl stroker crank in reply to AC, 03-30-2004 16:46:48
Try calling 308 489 5660. He had one awhile back.
ChadS
03-31-2004 07:05:12
 Re: Re: Looking for IH 6 cyl stroker crank in reply to Puller , 03-30-2004 18:16:21
A stroker huh? AC,, find you a good stock or rebuilt 301,, preferably a combine motor,, and tune it up from there. once you get this engine going, you can have fun, pull, and learn what it takes to make it run. You never know,,, a good 301 might have plenty of power for what you want to do. Are you going to Laotto? If so, let me know, Chad
AC
03-31-2004 18:31:14
 Re: Re: Re: Looking for IH 6 cyl stroker crank in reply to ChadS, 03-31-2004 07:05:12
Well, I work every other saturday...when is Laotto? If it is this weekend, I work, if it is next I can, and if it is the week after, I can try to get it off. I got this C263 home, and it isn't looking too bad on the inside. It has NO ridge, and I thought I could still see cross cut hatching on the cylinder walls....It says HT 101 on the stamped area on the side of the block, I can't figure out what that means..... later...AC
