Unstyled B
52 A Boy
04-04-2004 16:55:18
Would a unstyled B do any good on pulling? Without stroking it just bored .90 or .125 with pistons and some head work, how do you think it might do? Can you get it in 3100# class?
Thanks for any info.
52 A Boy
John
04-09-2004 20:53:48
 Re: Unstyled B in reply to 52 A Boy, 04-04-2004 16:55:18
Yes you can get into the 3100 class but you will be dissapointed. The unstlyed B is geared to high. First is up there close to 3 MPH and they just don't have enough motor to pull that gear unless they have some "help". IF you are lucky enough to have the optional lower first gear, then you might be ok. Gonna take some stroke if you want it to pull anymore. You can bore it a .250 and use early styled pistons, but you still need more than that to pull.
