Increasing a JD G valve spring pressure
al
05-03-2004 19:17:18
Thats's my question what is a proven set up to increase the valve spring pressure to about 90 lbs?
al
G-MAN
05-04-2004 07:51:37
 Re: Increasing a JD G valve spring pressure in reply to al, 05-03-2004 19:17:18
Shimming the springs up with washers under them will increase the on-seat and open pressure, but you have to make sure you don't get into a coil-bind situation. Plus, if the springs are also weak, that's going to make them weaker pretty quickly. Perhaps there is a spring for another engine that will fit correctly and give the proper pressure.
