Truck engine in tractor
560puller
05-03-2004 20:23:03
Has anyone put a RD372 or RD450 truck motor in a 460 or 560? If so, what all did you have to change?
JDBert
05-05-2004 07:06:10
 Re: Truck engine in tractor in reply to 560puller, 05-03-2004 20:23:03
I would also like to know about this. How bout a 501? What can be done to these motors, as far as stroking and boring, head work ect.
acme engineering
05-05-2004 18:00:58
 Re: Re: Truck engine in tractor in reply to JDBert, 05-05-2004 07:06:10
501s and 450s will go in a 460 or 560. Special flywheel work, grinding on block, motor mounts. A lot of work but worth the fun.
They are heavy motors.
650 ci out of a 501 is easy. 600 ci out of a 450 is fairly easy. Cranks have good counter weight for balance purposes at higher RPMs. 2.75 to 3 inch journals leave a lot to work with as far as stroking goes. Cam clearance is no big task if it is even an issue in most cases.
The heads are capable of 2.300 intake valves and runners are plenty big. Improvements are easy for a knowledgable head shop and performance is easy for a knowledgable head porter with either flow bench experience or a good working knowledge of fluid flow principles.
460/560
12-14-2005 06:28:38
 Re: Re: Re: Truck engine in tractor in reply to acme engineering, 05-05-2004 18:00:58
when you say grinding block, do you mean the rear flange of the block where it bolts up. it interfers with the frame rails doesn't it. i'm in the process of putting a 450 in a 560
Enquiring Mind wants to k
05-06-2004 07:42:02
Ain't you guys at Acme Engineering the folks that sold all that stuff to Wile E. Coyote in the Road Runner cartoons?
ChadS
05-06-2004 08:05:23
 Re: Re: Re: Re: Truck engine in tractor in reply to Enquiring Mind wants to k, 05-06-2004 07:42:02
HA HA HA HA!! ROFLMAO!!!! Chad
