Re: JD B rebuild question
lynn
12-10-2001 18:51:47
bguy..sounds like the sleeve is not long enough..if your machinist won't fix it or you don't want to tear down get another rod and cut the wrist pin end off and cut your rod and weld to get about 1/4 inch longer rod.. more if you want higher compression..take the other rod and use the wrist pin end to get the second rod the same length..this will extend the ring up into the cylinder..lynn
