ChadS
06-09-2004 07:20:25
Re: Re: OT,, BUZZMAN!! more 5.0 questions in reply to Buzzman72, 06-09-2004 05:10:23
I got it running!!! on all 8!! Regulator did the trick!! I searched high n low for that second pump, it only has one for sure. From what I learned,, they utilized the 2 pump system up until late 87 just talking about the Tbird now,,,,, then in 88 they changed them to the single high pressure pump in the tank. I got an adjustable regulator for it,, so I can turn up the pressure to get a bit more. I do still have to prime it to start it, but the plugs may have got gassed, and also, it will not rev up,,, as soon as I touch the throttle, it dies... also,, it has a vacuum leak.. with the leaks, it runs fine,, plug them off, it dies,, so somewhere there is yet another switch in there that is causing a problem. This SEFI is a very interesting fuel injection unit,, I was thinking later down the road,, to change the plentum,, to the truck style manifold,, they have 2 throttle butterflies, and it is about 6 inches longer in the runners. Wont fit under the hood though,,, lol!! Thanks for all your help!! Will keep ya informed on the progress. ChadS
