Wieght of 88
bill
12-13-2001 04:45:12
How much does a oliver 88 wiegh how light can you get them down to? What all do you have to do to a stock 88 that has wheelie bars & wieight brackets on it but the rest is stock. I want to get it down to the 4500 pound class but i weigh 220 so i need it to be down to # 4280 . tell me what all i should do. thankx
doug
12-13-2001 07:29:01
 Re: wieght of 88 in reply to bill, 12-13-2001 04:45:12
Andy Teasley has a STRONG 88 that makes 3750 lbs and with smaller tires would make 3500 lbs. It has aluminum wheels though, too! There is 1 or 2 in Missouri I think that make 3500 lbs also on 15.5x38 rear rubber!! WOW!!!
Jerry B
12-13-2001 06:18:39
I removed the belt pulley drive assembley and the pto from my 88. I replaced the factory hitch with an abbreviated Oliver 70 hitch. I replaced the heavey cast front wheels with new steel wheels and light weight tires. The rears are still on cast centers with 14.9 tires. I replaced the seat with an adjustable seat from TSC.
I weigh 240 lbs and on the scales "we" weighed 4540 lbs.
artw
12-13-2001 16:11:16
 Re: Re: wieght of 88 in reply to Jerry B, 12-13-2001 06:18:39
Pressed steel wheels on the front and rear. No hydraulics and no PTO ( 88's were available from the factory without them ) and you will have no trouble. Ours weighs 4100 minus the driver with 18.4 X 38's, wheelie bars and weight brackets. aRt
