JD A POWER
a puller
06-15-2004 20:33:08
I have a JD A we recently put together that has a 6.125x7.25 motor w/ a 60 head and carb. its ported and polished. what kind of power SHOULD it have. also, how much power should an A with 5.625x7.375 have for power, it has a cam w/ port and polish. I believe the guy is low on power. he runs 94 gas in it.thanks alot
oliver puller
06-17-2004 12:02:35
 Re: JD A POWER in reply to a puller, 06-15-2004 20:33:08
a john deere and power in the same sentence just dont make any sense
Dee in mid MO
06-17-2004 13:09:28
 Re: Re: JD A POWER in reply to oliver puller, 06-17-2004 12:02:35
chuckle... Hubby's Olie Super 88 beat the pants off a JD A in DivII higher wt classes in a brush pull. The A is a previous known winner. He's still scratching his head... We'll see what this fall's pull at the same location will do. I'll bet he's yanked that motor already & is wrenching on it. The chase will be on! :~) Dee
lynn
06-16-2004 18:20:30
a puller..the way i figure it the 6.125 should make around 63 to 65 hp at 535 pto rpm..we did a 5.625 x 7.500 a and it made 55 hp at 535..probably 1 less for the 1/8 inch less stoke..this a had 9.5:1 compression..lynn
mark
06-16-2004 20:53:32
 Re: Re: JD A POWER in reply to lynn, 06-16-2004 18:20:30
My A is 9.125 bye 6.500 have to cut a lot to make it fit but pulls nice. getting 92 hp on the dyno and likes to swist the back shaft. tractor is on 18.4 38 tires i have low and first gear .
2 Cylinder
06-16-2004 09:36:35
You'll have to take it over to your cousin's and put it on their dyno.
a puller
06-16-2004 11:20:24
 Re: Re: JD A POWER in reply to 2 Cylinder, 06-16-2004 09:36:35
ya, we just bought one. I was interested in how much they SHOULD run. the 6.125x7.25 one ran 58 as soon as we got it put together. the other one is a friend of ours. I just want to make sure I have the right person..is this dan? or is this one of you spiess(sp) boys? thanks alot, a puller
2 Cylinder
06-17-2004 16:38:50
 Re: Re: Re: JD A POWER in reply to a puller, 06-16-2004 11:20:24
This is no spy, you got the real deal! Sounds very promising.
JDGnut
06-16-2004 12:42:25
I would be very dissapointed with that engine only producing 58HP... with that kind of work.. but it will depend on your compression.. the 60 head gives you a large combustion chamber... but good flow.. Are you running custom pistons.. or the powerblock pistons... I am comparing HP numbers to a G... I don't have my A together... I would that closer to 70hp or more would be more ideal...
JDGnut
a puller
06-16-2004 20:35:55
 Re: Re: Re: Re: JD A POWER in reply to JDGnut, 06-16-2004 12:42:25
well, I dont' believe an A breaths like a G, b ut I don't know for sure. we need to put it on the dyno again since it was a FRESH engine, like 15 minutes put it on the dyno. I believe it has picked up power since with 16.9x38 tires are on it and you can dang near spin the tires in 5th by crackin the throttle. what about the A 5.625x7.375? should it run more then 50 hp? thanks alot, a puller
JDGnut
06-16-2004 22:02:51
 Re: Re: Re: Re: Re: JD A POWER in reply to a puller, 06-16-2004 20:35:55
I really have no idea.. the compression will make a big difference... I havn't run any A's of thoses sizes on the dyno.... It will be at least a yr before I have my A running.. JDGnut
a puller
06-17-2004 08:15:53
 Re: Re: Re: Re: Re: Re: JD A POWER in reply to JDGnut, 06-16-2004 22:02:51
how many horse are you supposed to have out of this? trying to find where I stand and if it needs worked on again....lol..
JDGnut
06-17-2004 20:00:47
 Re: Re: Re: Re: Re: Re: Re: JD A POWER in reply to a puller, 06-17-2004 08:15:53
I have no idea what the tractor will make.. 5.75 x 9.. 60 head, 70 carb... I'll be lucky to have it running by Christmas... but She'll be on a good diet... If she's not in the mid 70's or more... She'll taken apart.. and redone... I am expecting more than that.. JDGnut
