I went up and worked the track last night, looks pretty good for not using it in a year!! 300ft track, but percentage pull, entrace will be right off of IN 14, signs will be posted. Plenty of parking. RULES, 57 and older, div 1 and div 3 only 15.5 tire limit 3 mph farm stock 4 mph for mods farm stock must be stock in appearence,, stock hitch, 28 inches from center of rear axle, wheelie bars recommended. 18 inches hitch hieght LOW GEAR ONLY, no cut tires 10% rpm rule Weights in stock location only, no suitcase weights on farm stock. Mods are basicly div 3 rules, but 15.5 tire limit, cuts allowed, 18 from center of rear axle, 20 high. wheelie bars and kill switches are a must. any gear, 4 mph, weights cannot extend 11ft from center of rear axle, to the furthest point forward. Info and rules are available at the pull or email, or call, 574-893-7437 for track info. ChadS A chain will be attached to the front of the tractor to measure front end raise,, front ends cannot raise over 20 inches, or you will be DQed. So weight front ends accordingly.
