RE: Lightweights - Best 2500#-3000#
CASEPOWER
06-24-2004 20:02:12
How about a Fordson?? 251 stock cubes. Shipping weight 2970# Anyone seen one pull??
milky2390
06-26-2004 05:41:30
 Re: RE: Lightweights - Best 2500#-3000# in reply to CASEPOWER, 06-24-2004 20:02:12
We have a 41 case vc that we pull in stock form in 2500 pound class that used to win regularly. But the 34" tires can't compete with the 38's on a freinds 66 oliver that he lightened up nut to mention the extra hp. The vc didn't have a low enough gear to pull in much higher classes but the continetal motor has parts readily available to go to 162cu in that block. That won't make a wild thing but the 35 or so hp will help a little.
milky2390
06-26-2004 05:44:07
 Re: Re: RE: Lightweights - Best 2500#-3000# in reply to milky2390, 06-26-2004 05:41:30
Vc has the same motor as the cockshut 20/e2 and the little massey. I think
shutt30
06-25-2004 20:32:27
Never seen a old fordson pull. My dads 20 Cockshutt does a nice job in 2700 - 3200. The only real problem he has in 2700 are the wc's.
joecool
06-25-2004 16:30:52
we have a AC CA that is hard to beat in 3500-4500 on a good track. I am limited to tire size, with small 24's. usually beat super c's, H's, fords?(ha), in lighter classes it just spins out. it has 3 low comp. pistons, 1 gas piston. dad's CO case is mighty strong, and it still has 3 7/8 kerosene pistons, we have 4 inch gas for it.
Mopower
06-25-2004 04:27:17
Yes I have! Almost forgot. Those are quite the machine. I thing I saw one pull in 3500. I forgot the fellas name. Usually does good in stoneboat class.
