Quick Easy Air Pressure Adjustment
720Deere
06-25-2004 08:02:51
I stumbled across an add in a 4x4 magazine the other day that would be useful for us tractor pullers. A company called Equal Air makes a gadget with 2 - 8' air hoses, quick attach air chucks, gauge & quick dump valve. Attach the 2 hoses to your valve stems and you can either bleed of pressure or add pressure quickly and easily to both tires at the same time. The best part is the tires will balanced.
The bleed off valve appears to be high volume unlike those wimpy little valves on a regular gauge. They are a little bit pricey, but I doubt that you could fabricate something similar for the price.
Taxpull
06-26-2004 05:51:13
 Re: Quick Easy Air Pressure Adjustment in reply to 720Deere, 06-25-2004 08:02:51
Cost $61.00 at my local N A P A dealer.
Pete
MAD DUC
06-27-2004 07:40:44
 Re: Re: Quick Easy Air Pressure Adjustment in reply to Taxpull, 06-26-2004 05:51:13
There is one made by Percy's sold thru Jegs and Summitt for $40.
720Deere
06-25-2004 08:04:54
Sorry, the link didn't show up for me. WWW.EQUALAIRUS.COM
Ironman
06-25-2004 15:43:48
 Re: Re: Quick Easy Air Pressure Adjustment in reply to 720Deere, 06-25-2004 08:04:54
You can make these a little cheaper than that. I made 3 or 4 years back with stuff from the parts store. A gauge, two air lines, a T to connect the three, and two quick connects on the end.
