JD Governor Weights
Brad
07-14-2004 19:56:33
Has any one played with the weights in a JD governor? Do lighter or heavy weights have a advantage over the stock weights for throttle response or for lugging. Thank's for any info.
Flogger
07-15-2004 14:47:32
 Re: JD Governor Weights in reply to Brad, 07-14-2004 19:56:33
I keep hearing all this talk about governor springs and weights. I know on my tractor the linkage opens the carb, and the governor closes it. Unless you're trying to run higher rpms I just don't see much gain in messing around with it.
G-MAN
07-15-2004 15:58:51
 Re: Re: JD Governor Weights in reply to Flogger, 07-15-2004 14:47:32
I tend to agree. A two-cylinder governor tries to strike a balance between spring tension created by throttle position and centrifugal force created by the weights as they rotate and are flung outward. As long as the governor is opening the throttle fully under load to begin with, changing weights or springs isn't going to affect that. It may slightly change the operating characteristics of the governor at idle and part throttle, and change how fast it opens up, but it's not going to gain you horsepower. And at the low engine and wheel speeds that most two-bangers operate at, I can't see an advantage if a modified governor opens the carb two seconds sooner than it would otherwise.
LW
07-16-2004 18:57:21
 Re: Re: Re: JD Governor Weights in reply to G-MAN, 07-15-2004 15:58:51
I have to agree wiht Flooger and G-Man if its working leave it be because no matter what you do the governor weights and spring they have to work together, and in no way will you ever gain any horsepower from "fooling" with a governor.
exactly
07-15-2004 20:55:44
and in some cases..response timing is key..
buickanddeere
07-14-2004 20:53:30
Just adjust the throttle linkage tighter (bending the governor spring more) it hunts a little at idle. With the passing of 44+ years the spring gets tired or maynot have been set correctly in the past.
i believe you should talk
07-14-2004 22:30:56
 Re: Re: JD Governor Weights in reply to buickanddeere, 07-14-2004 20:53:30
i believe gman has some b weights in his G..or else it was JD G nut..can't remember for sure since it was several years ago..but i have heard the lighter ones open quicker as they should cause there lighter..lol..so some experimenting..let us know whay u find out..
JDGnut
07-16-2004 15:00:26
 Re: Re: Re: JD Governor Weights in reply to i believe you should talk, 07-14-2004 22:30:56
The original Gman (Gman413) has the B weights in his... I have mine drilled and shaved.. and balanced them.. (match the weight of the two.)
JGDnut
buickanddeere
07-15-2004 05:15:40
Lighter weights rev higher before there is enough centrifical force to pull the linkage.
question..........?
07-15-2004 10:51:28
 Re: Re: Re: Re: JD Governor Weights in reply to buickanddeere, 07-15-2004 05:15:40
if the b govorners work on them, then shouldn't they work on a G? the linkage dont' work very hard so they should run it ok and quicker right? quicker as in opens faster since there lighter...? thanks alot for any info
ChadS
07-15-2004 11:35:56
 Re: Re: Re: Re: Re: JD Governor Weights in reply to question..........?, 07-15-2004 10:51:28
I would look at the spring,, that seemed to help the G I worked on,, I put a small piece of baling wire around the spring, and the linkage to set the 10 over rpm, just slides along the spring assembly, and Used a piece of tape to hold it in place. ChadS
we run strings too...
07-15-2004 20:49:54
 Re: Re: Re: Re: Re: Re: JD Governor Weights in reply to ChadS, 07-15-2004 11:35:56
we run strings on the governor..but the weights would make a different effect if you dind't run strings...we use hoseclamps..and on our stoked A we have a double spring..but we dont' run it wide open..its only 7.25"..but it shakes so bad that we don't like to wind it..:S....our family likes to wind them 2cyl....we got an A we specifically like to wind..prolly 2k plus...
ChadS
07-16-2004 00:11:44
 Re: Re: Re: Re: Re: Re: Re: JD Governor Weights in reply to we run strings too..., 07-15-2004 20:49:54
Is it an older A? Why would it be so out of balance? How about the governor weights from like the newer models, for the B, a 50, or 520,530, A 60-620-630, G,70,720,730? Is any of those compatible? Those governors run a duplex carb, so would they be any more sensitive or respond any different than the older ones? Chad
